I am trying to find the affect of a light shelf in a daylighting analysis. I am exporting to Radiance with these settings:
Sunnywith sun
over analysis grid
include material definitions
indirect reflection = 4
Illuminuance Lux
model detail = high
Light variability = low
I have the following materials:
Clear single glass
white painted concrete ceiling
concrete floor
glass wall on the opposite side of the bay
1200 deep stainless steel light shelf
I tagged the light shelf as a reflector and I can visually see the rays bouncing in the space. But the daylghting analysis does not show the interior of the room with higher light levels from the reflected light.
The analysis grid is at desk height and the buidling is located in abu dhabi
Could you tell me what I am doing wronge. The reflected light should be read by the calculation, correct?
I actually want to use a system light these lightlouvers, but when that was not calculating correctly, I thought that I would test the software with a very simple model.
http://lightlouver.com/lightlouver-description/
Thanks for your help!
