Ecotect Analysis Forum (Read Only)
Daylight Factor is soooooooooooooooo wrong!!!
6 REPLIES 6
aschneider1
3576 Views, 6 Replies
I have been getting the craziest Daylight Factor values!  What should be 1-3% is coming out 14-54%!  Is there a setting that could have been changed somewhere to change my values?  THanks!
Adrianna Schneider, LEED AP
AEC Solutions Engineer
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
6 REPLIES 6
arqyt
in reply to: aschneider1
Try to verify the normal vector of the wall inside, i think it must be reverse.
Jose M Carralero.
ArqyT
aschneider1
in reply to: arqyt
I'm sorry, I am not sure where to do that...can you please point me in the right direction?
Boesselmann
Dear Schneider
from my experience the daylight simulatin within Ecotect is not very reliable, however your results are really far off.
If you should not have done this simulation by exporting the model to Radiance try to do that.
regards
tasleemkhan74
in reply to: Boesselmann
I have been working in Ecotct for a long time. Acoording to my observation, if we calculate daylight factor in daysim, it gives absolutely wrong results. However, the same i have done in radiance as well to check out the result, which always give me the perfect result.
So, I would suggeast you to use radiance to perform daylight simulation not in daysim.
arqyt
forgive the delay, Display/Surface Normals or ctrl+F9 you can see a vector that must point outside the zone. You can select the face/surface and Modify/Reverse Normals or with ctrl+R change that to the other option. With my little experience, we must review all imported model, and with overlapping windows/doors.
Hope i´ve been helpfull. Bye
Jose M Carralero.
ArqyT
aschneider1
in reply to: arqyt
Thank you all for your responses!  After doing an Inter-Zonal Calculation, I was able to fix the problem...but I certainly appreciate all the feedback!
Adrianna
