Ecotect
Ecotect
2 Kudos
Post 1 of 7
Daylight Factor is soooooooooooooooo wrong!!!
2926 Views, 6 Replies
03-09-2011 05:03 PM
I have been getting the craziest Daylight Factor values!  What should be 1-3% is coming out 14-54%!  Is there a setting that could have been changed somewhere to change my values?  THanks!
Adrianna Schneider, LEED AP
AEC Solutions Engineer
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
forgive the delay, Display/Surface Normals or ctrl+F9 you can see a vector that must point outside the zone. You can select the face/surface and Modify/Reverse Normals or with ctrl+R change that to the other option. With my little experience, we must review all imported model, and with overlapping windows/doors.
Hope i´ve been helpfull. Bye
Thank you all for your responses!  After doing an Inter-Zonal Calculation, I was able to fix the problem...but I certainly appreciate all the feedback!
Adrianna
Valued Contributor
2 Kudos
Post 2 of 7
Re: Daylight Factor is soooooooooooooooo wrong!!!
03-13-2011 12:02 PM in reply to: aschneider1
Try to verify the normal vector of the wall inside, i think it must be reverse.
Jose M Carralero.
ArqyT
2 Kudos
Post 3 of 7
03-14-2011 09:59 AM in reply to: arqyt
I'm sorry, I am not sure where to do that...can you please point me in the right direction?
4 Kudos
Post 4 of 7
03-16-2011 01:49 AM in reply to: aschneider1
Dear Schneider
from my experience the daylight simulatin within Ecotect is not very reliable, however your results are really far off.
If you should not have done this simulation by exporting the model to Radiance try to do that.
regards
New Member
0 Kudos
Post 5 of 7
03-17-2011 11:44 PM in reply to: Boesselmann
I have been working in Ecotct for a long time. Acoording to my observation, if we calculate daylight factor in daysim, it gives absolutely wrong results. However, the same i have done in radiance as well to check out the result, which always give me the perfect result.
So, I would suggeast you to use radiance to perform daylight simulation not in daysim.
Valued Contributor
2 Kudos
Post 6 of 7
03-22-2011 06:00 AM in reply to: aschneider1
Jose M Carralero.
ArqyT
2 Kudos
Post 7 of 7
03-22-2011 10:31 AM in reply to: arqyt
Adrianna
