Good morning,
I am trying to generate two images + associated tabular data showing cumulative sky luminance for Lausanne in Switzerland
I have found that with the Sun-Path diagram tool I can plot diffuse and direct total annual radiations (see attached)... I have a few questions:
Thank you very much for your help!
Fred
I'm no expert but ...
The accompanying graphs that correspond to shadow masks, and display these diagrams correspond to the "object you have selected." Each object has different diagram
If you intend is to have a model for analyzing luminous sky, what you intend is the model of sky known as "Perez", some analysis programs use this type of sky. Luminance is proportional to the radiation received in each solid angle ... Perez sky model. Ecotect doesn´t use that type of analisys directly.
If you intend is to have these values of incident radiation... use a clean model, the proposed location ... only model a horizontal surface and calculates the shadow mask, you get these values you want.
For the other questions .... I would have to inquire how they could be.
Anyway, that's what you want? is for some research?
Hope that helps some you.
regards
