Ecotect Analysis Forum (Read Only)
Creating stacked Zones
1 REPLY 1
345 Views, 1 Reply
1.Whenever I create a thermal zone defined by 4 Corner points the default height of the zone is 2400 m! Can I adjust the height before?
2. When I adjust the height afterwards to 3.3 m it works but is anoying to do for everx surface!
3. When I stack two zones on top of each other for a two story building the Interzonal- adjacencies calculation always leads to errors 1050 and 1051?
Help Please!
1 REPLY 1
under File menu->User Preferences->Modelling Tab->Default Zone Height.
You can change here your settings prior to model your building zones.
Hope this helps
Giulio
