Ecotect Analysis Forum (Read Only)
CPU Usage while analysing
1 REPLY 1
Mehrad.Mahnia
684 Views, 1 Reply
Dear all,
I'm working with Ecotect 2011 32 bit and while the software is analysing, the CPU usage doesn't go more than 17% and it takes too much time to analyse a simple Solar access analysis on a surface which has been divided 3 by 8 (a 3*8 grid) . . . some time around 1 hour for a simple analyse. I was wondering if anyone here knows what the problem is . . .
PC Specifications:
OS: Win7 64bit
8.00 GB RAM
CPU: Core i7-2600 @ 3.40 GHz
System Rating: 7.1
Ecotect 2011 32bit
Many Thanks
1 REPLY 1
m.soderlund
in reply to: Mehrad.Mahnia
Ecotect doesn't have any support for multi-threading, hence why you get the slow performance. I guess your processor can handle up to around 6 (?) threads which explains your CPU usage of around 17 % (100 / 6 = ~17 %)
Autodesk does not even seem to lift a finger to fix it either
