I live, study and work in Mareeba, Qld. Australia, and most of the projects I am likely to work on are in this area.
How can I import more accurate climate files as those given for Brisbane are more than 1000km south of here, and our climate is VERY different.
Is it possible to access the climate files from AccuRate, or BERS as developed by CSIRO and load them into Ecotect?
Solved by jon.gardzelewski. Go to Solution.
Any climate data in CSV Column Separated Values can be translated to .wea through the weather tool. You need to track the values for each column from the format that you have.
The Find Weather data lets you download hundreds of climate data files for all major cities. Need to unzip the EPW file, load into weather tool and save as WEA file.
Dear Greenstefan,
I have looking highh and low for weather data of Ho Chi Minh but to no avail.
I came across your thread and found some hope. Can you shed more information on your post?
Any exact website to point to? Many thanks in advance.
ChinC
