I created a 3d model of a house on Revit.
The problem is that when I import it into Ecotect I can't see some curtain walls. I used the the curtain wall tool to draw them.
The odd thing is that some of the glazed curtain walls are visible and some not even though I drew them using the same method.
Does anyone know how I can solve the problem?
Thank you very much for help.
Caterina
Solved by Pennetier1. Go to Solution.
Thank you very much!
I will do as you have advised, and perform simple calculations to get the perspective. I am currently modelling the thermal model and will definitely be back for more clarifications regarding the calculations.
Hello Caterina,
Thank you for starting this thread 🙂 I have learnt a lot. I hope to catch on up and be as good as Pennetier.
All the best in your project.
DAISY.
