I am trying to fill a polygon with nparticles (water), so that I can animate it. I have tried many tutorials, but i can get them inside the polygon. The object is very the and has an irregular shape.
Any help will be greatly appreciated.
several ways to go about doing this. What methods have you tried ? Did you try using fill object with nParticles? If so you probable realized that once the liquid particles settle they become quite compact and only fill about 25 percent of the object. I would never use nParticles to simulate fluid simple because of how many nparticles are needed and how slow meshing nparticles can be. I need more information about the object you are trying to fill.
Hello Aniflex9. I have tried to convert the polygon with ncloth before filling it with a liquid, but the particles appear to be on top of the object. They are also not covering the entire area. I tried to play with the particle fill options, but it has not solved the problem.
I have also tried to convert the polygon into a passive collider, but the results were the same.
Okay. I'm not sure why he didn't reply to your original thread, but....whatever.
Hello. I did try to upload it,but it didd accept the file format. I have added a dropbox link. https://www.dropbox.com/s/3t90yd97759vvct/a.mb?dl=0 Thanks.
