Hi Guys,
Im currently doing some fluid caches, everything caches fine until I up the resolution, then whenever the cache file exceeds 2.5gb the scene crashes. This happens on windows and mac, locally or on the network.
I'm using an auto resized container and emitting from geometry.
I knew there was a cap a few years ago but I though it had been changed?
Thanks in advance for your help.
James.
Hi Adrian,
Thanks for the reply.
Weirdly my settings are set to .mcx and per frame cache file but still capping.
I'm not very experienced with maya fluid so trying to figure out any issues im having.
Another problem I am having is that I can get a low res sim how I want but when I increase the resolution, even if only by a small amount the simulation completely changes and is unusable. Is this the right workflow to use? I always assumed that once getting the low res sim right I could just increase the resolution?
James.
Are you writing out per-frame caches? Or to one, huge cache? Make sure to select 'One file per frame' when you run your cache. Dealing with insane file sizes is not pleasant. Also, how much RAM is on your machine? Your machine may be hitting limits with how much data it can push.
Unfortunatley, you can't just increase the resolution of a Maya Fluid and expect it to behave the same. This is just the nature of the Fluid solver. Certain fluid attributes will affect your sim as you change the resolution of your container, as there's more voxels to affect the velocity data.
I'm sure Duncan can chime in on this.
