MAC OsX. 10.9.5 Maya 2015 SP5. Yes, I have reinstalled (including removing Maya) and removed the prefs.
When I create a rigid set I get no INTERFACE, gone. Nothing. Nada. See image below.
When I create a regular "single" rigid body, I get interface options.
I can't figure this out. Am I the only one having this problem?
Solved by ArtifactDesign. Go to Solution.
The set options are under the bulletsolver node. see attached.
hope this helps.
