I have a strange problem with this file. The preview thumbnail that comes up for the block in design center on the righthand side shows it just fine. But when you bring the block to the tool palette, it doesn't show an image that quite matches the block.
I've tried right-clicking for "update block", I've also tried _blockicon in the file, and I've checked for weird text settings in the block that could be throwing it off. No luck.
Can anyone figure out what's causing this?
Thank you!
It seems CAD is confused by the width on the polylines. As a nice workaround you can explode the block down to linework, select all and change go to the properties palette, look at just the polylines, select global width and input 0 (even though it already says 0...). Then select all the linework, do a control-shift-C and control-shift-V to paste it as a block with all 0 linewidth. Grab that block and drag it to the tool palette (not with a grip). Then locate the image and set your original tool image to the new tool image.
Not all of the linework has global width (e.g. arcs, lines, etc...). When you select all of it, you need to 'look at just the polylines'. To do so, after selecting everything, look at the top of the Properties Palette. There will be a field that says what you have selected and it will say something like "All (132)". That field is a pulldown menu. At the right of it is the little down arrow. Click it and it will describe what items you have selected and allow you to choose just polylines. Alternately, if you explode a polyline it will turn into lines/arcs and lose its width information in order to become 0 width. You could do another explode on everything and have it result in all zero width.
