Hello all,
I am having a problem making dynamic block with several connected distance parameters.
Ie. I have lavatory plate with who wash basin. I have certain constraints to keep , please see attached image but I cant make it work... I have also attached block to see how far I got...
Jan
Here's a version using dynamic parameters/actions. If you need it with constraints instead, let me know and I'll , but it's easier/simpler/more effective to use the dynamic parameters/actions.
I decided to make up the constraints version. See attached. It works fine and was easy enough to do, but is absurdly more work to get fully functional over the version with dynamic parameters/actions.
It isn't if you make the individual sinks separate blocks.
See attachment
I made the constraints versions and simply forgot to attach the file to my last post. I considered making the sinks blocks, but did it without. Regardless, even as blocks it is still more complex than the dynamic parameters/actions version. It's all more easily and more accurately done with parameters/actions.
hi!
I think You added wrong version of file with parameters/actions therefore I add this
Regards
Juris
