Dynamic Blocks Forum
Using BATTORDER seems to goof up Visibility States?
4 REPLIES 4
mdhutchinson
305 Views, 4 Replies
I had my Visibility States working as I wanted across 80 states...
Then I found occasion to use BattOrder to reorder the Attributes.
Afterwards, the Visibility States were goofy.
Has anyone seen this?
Is there are work-a-round?
4 REPLIES 4
Never done it but I wonder if doing so casuses the Vis Show State to get lost in the shuffle.
(Excel does well at keeping relationships when a formula is re-ordered. Maybe AutoCAD can't?)
in reply to: mdhutchinson
Does it do anything different with BATTMAN?
(if ("mysolution"=answer) then (click "Accept As Solution"))
Charles_Shade
Never tried.
Do you have a backup of the Block you can go back to?
I didn't save the drawing in which I was working on the block... so I just closed without saving. The dyn block is actually inserted in this drawing, so I was able to work on it, then test it out, then save my work if I was happy with it.
I need to edit the battorder... so I guess I'll have to just edit the visibility afterwards.
”Boost
”Tips
”Services
