Hey,
I am trying to create a dynamic block for a truss plate where i can stretch it up and down, but i want the little holes to increase in number as i stretch it. Is there a way to do this without using the visibility action? The visibility action is way too time consuming. hope this makes sense.
thanks
Solved by Libbya. Go to Solution.
ok i uploaded the block, can someone help me with this? I am trying to stretch it horiz and vertical and want those stars to increase/decrease in number as i stretch it.
I don't use dynamic arrays enough to feel like I'm good at it so there may be an easier/better way, but the attached block seems to work the way you want.
So could you explain to me how you fixed it? I see you added the array action to the stars and chained them, but when i do the same to my block it doesnt work right. What am i missing?
I added a chained XY parameter and then added an array action to it that had the stars in the selection set. Maybe you are using a linear parameter instead of an XY? Maybe you didn't change it to chained?
I did all that, but it still does not work right. I attached it again, maybe you can figure out what i am doing wrong.
You were not doing anything wrong. As a step in diagnosing why it wasn't working, I changed the XY parameter to display 1 grip so I could determine if the issue was with the stretchs or with the XY. I did nothing else and it immediately started working correctly even after I turned the grip back off. I'll call that a CAD glitch. Also, if you insert a new occurrence of the block it immediately works correctly.
It sure looks like it was a CAD glitch. when I reinsert the block it works correctly. thank you for your help!!!
Hi
Ive just tryed to make similar plate dynamic, but i cant make the array work and fixed on the size
i have now tryed to make it after your block, but it still isnt working for me
are you making some settings for it to work? or something.
Kind regards
Lars - Denmark
Let me start by thanking Libbya and the poster. Without finding this solution I would never have been able to fix my own problem using the array in a dynamic block. Don't mean to be critical but as this block works when it does the array it will put lines over top of lines. I have attached a file that fixes that problem. There are a lot of notes in the drawing next to blocks that I think it makes it easier to read and understand. I hope it is OK to post this as I think it might help some other people later on. There is also a bug in what I have that for my way of using it does not hurt anything. Explained inside of the drawing as you can see if you download.
