Dynamic Blocks Forum
Titleblock, rectangle
1 REPLY 1
157 Views, 1 Reply
ARRRG!
Trying to make one block for all our titleblock (A, B, C, D, E).
How do I chain stretch both in X and Y with one command. I would like to choose from a drop down list the format, and that the contour adjust itself to the proper size and that the Title block section relocates itself.
I'm sure it has been done already, can someone post an example.
Else can someone show me how to stretch a rectangle from one corner.
Thanks.
1 REPLY 1
use the x,y parameter and use the lookup parameter with the 'allow reverse lookup' selected from the default 'read only' you can then 'program' the desired sizes in a pulldown.
one solution i did (with sheetsets) was to create different sized titleblocks in separate layouts in the SSM dwt file, and upon job creation, use the desired layout as the default title template. Message was edited by: cnibbe
”Boost
”Tips
”Services
