Dynamic Blocks Forum
Text problems with flip parameter
2 REPLIES 2
bgingerich
426 Views, 2 Replies
Attached is an example of the problem.  The block works fine in the test block window and if I reinsert it into the same drawing, but when I insert it into a different drawing, the text gets flipped backwards.
Any ideas?
Brandon Gingerich
2 REPLIES 2
ojuris
in reply to: bgingerich
mirrtext set to 0
bgingerich
in reply to: ojuris
Thanks! Works great.
Brandon Gingerich
”Boost
”Tips
”Services
