I am creating a dynamic block to do details for structural framing. Attached is an example that I am stuck on. the widget plan and end plan went pretty good. But when I got to creating a cope on the ends I got stuck. I am attempting to stretch the required cope as you can see in my attached drawing. For some reason I can not get the end line to move with the horiz cope line. If you have any suggestions it would be deeply appreicated.
Thank you - BC
Solved by Charles_Shade. Go to Solution.
Not knowing what the end line is is this what you need to happen?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Stretch Actions can overlap Stretch Actions.
Try this though - Move the Selection Set box for Stretch5 to the left so that it does not cover completely the right end of the horizontal entities that are included in the Selection set.
Falls apart doesn't it?
