is there a way to make dynamic blocks stretchable similar to a mleader,
the blocks i create are only stretchable by grips, and not by crossing
(i am using linear or point parameter stretches)
TIA
m
Can you post an example of what you want?
The Dynamic Properties are not accessable with a Crossing window.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
If you're building a dynamic block that you want to act like an mleader you might want to play around with the polar parameter. That might solve your problem.
Dave.
