I just recently noticed a strange behaviour when using the rotate action with the toilet dynamic block. Insert the 'toilet' from the tool palette and select the 'elongated (plan)' view. Then rotate it 90 degrees using the rotate action of the dynamic block (using the circle grip) then rotate it again to it's initial angle. Now you notice that the block didn't really return to it's initial state, If you zoom in you will notice that the horizontal and vertical lines of the block appear jagged. Select Tools->Inquiry->Distance and select the endpoints of the upper horizontal line you will notice that DeltaY is now different than 0.000.
Anybody else have experienced this?
