Dynamic Blocks Forum
Sharing parameters between blocks
1 REPLY 1
cve60069
593 Views, 1 Reply
I wish to have a single dimension alter the dimensions in a set of nested blocks, similar to shared parameters in Revit. For example, I have a circle that has a fixed diameter that I wish to control in all blocks.  I have set the diameter to barDia so now I wish to manipulate the dimension from outside the block.
Am I able to share the parapeter across all the blocks, please?
Regards
1 REPLY 1
AcadAdamLT
in reply to: cve60069
No, you can't share it between your blocks.
But however, if all blocks are similar or of a similar type/name or other properties you can use Qselect to select all blocks in a drawing containing that parameter and edit the value of all those blocks in properties window.
(Use a stretch action to alter the dimension)
Signature, sincerely... //Adam
AutoCad LT 2016
Give Kudos where credit is due, Mark "accepted as solution" if the post solved your question.
”Boost
”Tips
”Services
