Dynamic Blocks
Dynamic Blocks
Valued Contributor
0 Kudos
Post 1 of 2
Sharing parameters between blocks
194 Views, 1 Replies
11-20-2013 05:45 AM
I wish to have a single dimension alter the dimensions in a set of nested blocks, similar to shared parameters in Revit. For example, I have a circle that has a fixed diameter that I wish to control in all blocks.  I have set the diameter to barDia so now I wish to manipulate the dimension from outside the block.
Am I able to share the parapeter across all the blocks, please?
Regards
No, you can't share it between your blocks.
But however, if all blocks are similar or of a similar type/name or other properties you can use Qselect to select all blocks in a drawing containing that parameter and edit the value of all those blocks in properties window.
(Use a stretch action to alter the dimension)
Valued Mentor
41 Kudos
Post 2 of 2
Re: Sharing parameters between blocks
11-21-2013 03:16 AM in reply to: cve60069
Signature, sincerely... //Adam
AutoCad LT 2014
Give Kudos where credit is due, Mark "accepted as solution" if the post solved your question.
