I needed to create a block for all our schematic work. Right now were are doing the scematic part in Visio, but like to move that part to auto cad if it is possible.
I wonder if this is possible to create though.
A dynamic block that you can drag out to expose more terminals
To be able to lable the terminals individually
For each wire terminal to provide a snap function so lines can easely snap to them
Be able to lable each wire that gets vonnected individually.
Be able to add a heading to each block for make and model number.
Not sure if acad can actually do all this with dynamic blocks, so make someone can chime in.
I attached an image from Visio as well.
Thanks!
It might take some work and some know how but it sounds possible.
Most of all it will take time to create all the desired functions and you may have to use more blocks then one to archieve what you want.
Search this Forum.
I think this has already been done or at least asked. May be a starting point for you.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
