Dynamic Blocks Forum
Rotation off by 1*
5 REPLIES 5
420 Views, 5 Replies
Rotation off by 1*
Can someone look at the attached block and tell me why when I rotate it, it "shifts" 1*... so instead of rotating to 90*, it's 89*, etc...
Any ideas?
5 REPLIES 5
ojuris
is it now ok?
Juris
in reply to: ojuris
Yes!
Can you please tell me what you did? I have other blocks doing the same thing.
Thanks!!!
Charles_Shade
In Juris' block the Flip Action and Parameter have been removed.
But zoom in our the Flip Action and Parameter in your version.
It is not running thru the center of the Rotation Parameter.
If you change this on yours does the Dyn Blk work as you need?
in reply to: Charles_Shade
Ah... yes. Now it does...
Now I know you have to zoom in really close sometimes. Smiley Very Happy
Thanks!!
ojuris
Sorry about delete parameter - that was my fault - I accidentaly delete it   Smiley Embarassed
The reason was, that your rotation grip was not on rotation parameter vertical axes and it is not depend from flip parameter. If You draw vertical line through rotation parameter centre - You`ll see what I talking about
Juris
”Boost
”Tips
”Services
