Dynamic Blocks Forum
Rotation in dynamic blocks
2 REPLIES 2
samerchakroun
3685 Views, 2 Replies
Hello everyone,
I am a little new to AutoCAD so bare with me,
I am creating a dynamic block, i set the rotation angle parameter to 45 degrees and set the action.
While testing the block it’s seemed to only rotated 90 degrees, is there a way to make it rotate
45 degrees all around?
2 REPLIES 2
You need to attach the block when posting the question, otherwise no one will have a chance to understand what the problem really is.
AcadAdamLT
in reply to: samerchakroun
What you should do if I understand you correctly (other then to post the block :)) is to set the Rotationsparameter to go 360 degree's instead and then go into properties for the rotation parameter and set "Ang type" to Increment, and set Increment to 45.
Try it out and see if you get the result you wish for.
Signature, sincerely... //Adam
AutoCad LT 2016
Give Kudos where credit is due, Mark "accepted as solution" if the post solved your question.
”Boost
”Tips
”Services
