Any ideas how to fix the angles on this block (attached in subsequent post)
after using the stretch action?
The initial insertion of the block works correctly. At the minimum size, the
angle reads 90° straight up, and 45° pointing to the upper-right.
However, after stretching the block to any of the longer sizes, the angle's
base point has appeared to forget to go along for the ride. The angle when
rotating to the upper-right now reads 135°.
All other similar posts I have read have had the opposite problem, where the
_stretch_ was wrong *after* a rotate. This is not my issue.
R. Robert Bell
