Made a north arrow with move and rotation. With Dynamic Input On, select the rotate grip and you can enter number of degrees which works fine. Turn DYN off, select rotate grip, enter the same degrees on the command line, press enter and the arrow does not rotate to the desired angle. I must be missing something simple.
Gene
