Dynamic Blocks Forum
Rotation Angle
4 REPLIES 4
227 Views, 4 Replies
Rotation Angle
Made a north arrow with move and rotation. With Dynamic Input On, select the rotate grip and you can enter number of degrees which works fine. Turn DYN off, select rotate grip, enter the same degrees on the command line, press enter and the arrow does not rotate to the desired angle. I must be missing something simple.
Gene
4 REPLIES 4
Hope I do this correctly; I have attached the simple north arrow.
It seems to work fine for me. what do you mean by the desired angle?
I see what Gene is saying. With dyn input on, it asked for input for the angle explicitely, with it off it only rotates to the crosshairs location.
Thanks for your reply; I am glad to know someone else is experiencing the same result. This issue is not a show stopper, but just would be nice to now why it does not work with DYNE turned off.
”Boost
”Tips
”Services
