Hi Everyone,
Looking for some help with this. Unable to get to work correctly because of limitations with LT. I have a block that I rotate around a circle ( fuel tank for oil field ). The angle, imperial and metric measurements are to update accordingly to certain values based on tank size. For this particular tank, each 1 degree is 0.4792". I can get the angle to update correctly, but cannot get the text to update according to the angle displayed.
Please have a look at http://forums.autodesk.com/t5/AutoCAD-LT/Block-Editor-Help/td-p/3179514
At this point, I am setting up visibility to update the numbers. Any help from users of full version is greatly appreciated.
Thanks!
