Dynamic Blocks Forum
Rotate and stretch in both directions
4 REPLIES 4
1234 Views, 4 Replies
I have created a dynamic block where I stretch a frame around a attribute in both directions, but as soon as I try to rotate the block the stretch goes skew.
What am I doning wrong with it?
4 REPLIES 4
steven-g
Your stretch parameter doesn't need to be chained when you have 2 actions working on it, chaining is only when you need different parameters to work together. And remove the stretch action from the rotation selection set. Sometimes actions from other parameters need to be included and sometimes they don't it depends on the parameter.
in reply to: steven-g
Thanks Steven!
See the attached final block.
steven-g
Thats it, you're welcome
Libbya
Almost any time I'm doing both a rotate and a stretch I prefer to combine them using a polar parameter and polar stretch actions.  If taking that approach, one issue that often occurs is that you cannot apply two (or more) polar stretch actions that act at the same time on a single object or else the rotations compound and the object is rotated twice as far as desired.  The solution to that issue is in the attached file and consists of adding chained point parameters at each stretch loaction and then using the polar stretch actions only on the point parameters.
”Boost
”Tips
”Services
