Is it any option to keep text righ-reading even if block is rotated (by AutoCAD command ROTATE, not dynamic action)?
Solved by gjrcmb. Go to Solution.
Solved by Charles_Shade. Go to Solution.
Welcome to the Autodesk Forums!
Can you expound upon your need?
What exactly from this thread are you trying to emulate?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
