I have tried searching forum with similar problem, but without finding similar problem.
I have a problem with dynamic block and hatch. I need to create a simple strechable rectangle with a solid hatch. I have managed to get it to work great while stretching block from grips. My problem is that if I try to manually write width and lenght in properties, the rectangle streches but hatch doesn't. Hatch updates to correct size if I click on grip. Any ideas?
Solved by Pirttimäki. Go to Solution.
