Dynamic Blocks
Dynamic Blocks
Active Contributor
0 Kudos
Post 1 of 9
POLAR ARRAY BLOCK
574 Views, 8 Replies
01-04-2008 02:11 PM
I am trying to create a block that polar arrays the street lamp, but every time i try i just move the grip for it, is there something i am missing?
*Gordon Stephens
Post 2 of 9
Re: POLAR ARRAY BLOCK
01-05-2008 02:39 AM in reply to: blkscrpn5
It might help to post the block in a container drawing.
Gordon
wrote in message news:5812899@discussion.autodesk.com...
Active Contributor
0 Kudos
Post 3 of 9
01-07-2008 06:42 AM in reply to: blkscrpn5
WELL HERE IS A DRAWING TO SHOW YOU WHAT I MEAN
*Gordon Stephens
Post 4 of 9
01-07-2008 07:02 AM in reply to: blkscrpn5
What form do you want your polar array to take? It looks like you want 90
degree rotation increments, but your distance parameter, although it has a
distance type of increment, your increment is set to 0. Try selecting the
distance parameter and adding the array increment you require in the
properties table.
Gordon
wrote in message news:5813822@discussion.autodesk.com...
Active Contributor
0 Kudos
Post 5 of 9
01-07-2008 08:25 AM in reply to: blkscrpn5
i want the block to array around the center of the circle, i dont need any distance for it, the idea is that the circle is a post and the square is a light coming off of it.
*Gordon Stephens
Post 6 of 9
01-07-2008 09:00 AM in reply to: blkscrpn5
Polar arrays are not possible - you might consider a simple rotation with
visibility states for 1, 2 adjacent, 2 opposite, 3 and 4 lights assuming you
will array them at 90 degrees to one another. Then if it is not at an angle
orthogonal to the world UCS, you could rotate the squares as necessary.
Gordon
wrote in message news:5813924@discussion.autodesk.com...
*Gordon Stephens
Post 7 of 9
01-07-2008 09:22 AM in reply to: blkscrpn5
Like this example I guess - I have set rotation angle increments at 5
degrees - you set what you want/require
Gordon
Member
0 Kudos
Post 8 of 9
09-28-2012 01:58 PM in reply to: blkscrpn5
Este es mi solucion que esta en proceso, aunque desearia poder controlar la cantidad de items desde afuera del bloque s
Member
0 Kudos
Post 9 of 9
09-28-2012 02:05 PM in reply to: blkscrpn5
esta es la version 2 no fue mucho el cambio pero la idea es mejor
solo autocad 2013
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
