Dynamic Blocks Forum
POLAR ARRAY BLOCK
8 REPLIES 8
Message 1 of 9
blkscrpn5
1012 Views, 8 Replies
POLAR ARRAY BLOCK
I am trying to create a block that polar arrays the street lamp, but every time i try i just move the grip for it, is there something i am missing?
8 REPLIES 8
Message 2 of 9
in reply to: blkscrpn5
It might help to post the block in a container drawing.
Gordon
wrote in message news:5812899@discussion.autodesk.com...
Message 3 of 9
blkscrpn5
WELL HERE IS A DRAWING TO SHOW YOU WHAT I MEAN
Message 4 of 9
What form do you want your polar array to take? It looks like you want 90
degree rotation increments, but your distance parameter, although it has a
distance type of increment, your increment is set to 0. Try selecting the
distance parameter and adding the array increment you require in the
properties table.
Gordon
wrote in message news:5813822@discussion.autodesk.com...
Message 5 of 9
blkscrpn5
i want the block to array around the center of the circle, i dont need any distance for it, the idea is that the circle is a post and the square is a light coming off of it.
Message 6 of 9
Polar arrays are not possible - you might consider a simple rotation with
visibility states for 1, 2 adjacent, 2 opposite, 3 and 4 lights assuming you
will array them at 90 degrees to one another. Then if it is not at an angle
orthogonal to the world UCS, you could rotate the squares as necessary.
Gordon
wrote in message news:5813924@discussion.autodesk.com...
Message 7 of 9
Like this example I guess - I have set rotation angle increments at 5
degrees - you set what you want/require
Gordon
Message 8 of 9
jimmy_alexander
Este es mi solucion que esta en proceso, aunque desearia poder controlar la cantidad de items desde afuera del bloque s
Message 9 of 9
jimmy_alexander
esta es la version 2 no fue mucho el cambio pero la idea es mejor
solo autocad 2013
”Boost
”Tips
”Services
