Somewhat new to parametric blocks, I've been working on parametric slotted base plate for a heat exchanger in which I've been successful in making the slot sizes change symetrically as well as the negative and positive x placement symetrical, unable to get the right hand row of slotted holes placed symetrical in the positive and negative y axis with the left hand row of slotted holes. Can anyone give me a clue on how this may be done? I am running 2010 AutoCAD within Windows 7.
So far the parameters work in the followin way:
d1 controls slot length with an equal contraint on all the other slots
r1 controls slot radius with an equal contraint on all the other slots
d2 controls base plate width with a symetrical constraint set to the vertical line in the defpoint layer which has a fixed constraint
d3 controls base plate height with a symetrical constraint to the horizontal line in the defpoint layer which has a fixed constraint
d4 controls x from edge of plate with a symetrical constraint on the vertical line of that slot and the one above it set to the vertical centerline
d5 controls y from the bottom of the plate with a symetrical constraint on the radiuses of the left upper and lower slot to the horizontal centerline
I just can't figure out how to get the right hand row of slots to place symetrically in the y axis consistent with the left hand row. If the slots were square, or if I could somehow fix a defpoint horizontal line to center of each slot, I could make it work, using that as a symetrical contraint to the horizontal centerline. But aparently, because the slots are radiused it won't. If I try to use a symetrical contraint on the radiuses or the vertical lines of the left and right slots it returns an error. And all the slots and the outline of the base plate must be on layer 0 as the edited drawing will be used to import into a CNC burn table software which selects layer 0 as the "burn" layer upon which the G code written.
Help will be much appreciated.
Solved by Libbya. Go to Solution.
IMO, parameters/actions play a lot nicer than constraints. I could accomplish all of what you are trying to do a lot more easily without using any constraints at all and only using parameters/actions.
Anyway, is this what you are after?
I added the two reference lines between the arc midpoints. I made the line endpoints and relative arc midpoints coincident and made the two lines equal.
