I need some help with this one.
I can not seem to proportionately stretch the raised panels along with the first group. I'm pretty sure the action is a second stretch but how do I get the second, third and fourth panel columns to stretch with the increments?
Do I use a chain action?
Solved by Libbya. Go to Solution.
IMO, the easiest way is to add three more stretch actions to your width parameter. You will need to change the distance multipliers to 0.75, 0.5 and 0.25. The stretch windows need to be in the appropriate places and the selection sets need to contain the correct linework. See attached.
