I have created a dynamic block of a ceiling fan. In the dynamic block, I have a distance & scale paramater that allows the user to select between 9 different diameter fans. I am trying to create and attribute that refers to either the diameter of the outer circle of the ceiling fan, or the distance of the linear dimension. Either way, once the block in inserted into a drawing, the field won't update when the fan is strectched. Has anyone else run into this problem or am I missing a step? I have attached my dynamic block for your use. Thanks for any help.
Jason
