Dynamic Blocks Forum
Nested Visibility States
1 REPLY 1
3649 Views, 1 Reply
I'm attempting to condense several hundred blocks of speaker schematics into 3 or 4 using dynamic blocks... my idea is to have one file per manufacture (xxx.dwg, etc), and then use visibility layers to allow for the selection of a model and wiring configuration.
Is it possible to do nested visibility states. Such as the first drop-down item would allow me to select a speaker model, and then a second drop-down would only show the wiring configurations that are specific to that speaker model? (i.e., a second visibility parameter that is dependant on the first).
Thank for the advice.
1 REPLY 1
This example show how to turn the wire on and off. Create visible state for each way you the block will look. Than add lookups to display certain looks.
”Boost
”Tips
”Services
