I have created a Vis parameter to change between each individual Client logo rather than having to copy and paste the logos from an external source each time we set up a title block.
I would like to be able to pick from a drop down list, the scale bars separately so that i can choose either 1:100, 1:50, 1:20 etc.... as an independent of the rest of the block.
If i could get this to apply to the scale bar then the same could be used to change Company logo and the status of the drawing as well within the block.
From what I have seen Thomas created a large amounts of lookup fields separate to the one Vis parameter, which then allowed each individual parts of the DWG to be selected via the drop down menus.
Although I understand the basics of this concept, I have not managed to grasp how he has used the look ups for each table to allow for the Vis parameter to manipulate each individual aspect of the block. I have tried to create a look up for each part and then select the Vis parameter in accordance to what should be seen, i.e.
1. Client Logo - Leadbitter, Carters, Cooper Construction, Pye, Inspace
2. Status of Job - Preliminary, Subject to technical, Building Regs, For Construction, As Constructed
3. Scale Bar – 1:10, 1:20, 1:50, 1:100, 1:200, 1:500
4. Company Logo – Gemmabds or Passenger & Peachy
All of these would need to be independent Lookups which then relate back to the one Vis parameter but when selecting say Carters as a logo then it also shows the Preliminary and 1:100 bar at same time
I would then try to select the scale bar but that would bring up the Inspace logo at same time. So you then have multiple Clients and Scale bars shown at once, I think this has something to do with having an ordering system of some type so that I can select each independent of one another.
Any suggestions would be much appreciated
Sorry if this is a bit jumbled or hard to understand, its difficult to explain how things work when you don’t understand the full concept of what you want from the dynamic block being created 😉
Adam
