I have a dynamic block, that represents a stirrup.
I inserted in the block a Block Propreties Table, that have some preset dimensions for the stirrups. The grip of this table I decided to put in the top right corner.
The problem is that I can't make this grip moveable )
Please help, if it is possible )
See the attachement with the block
Thanks in advance.
Top two Threads in this query:
Second one down is a workaround if it can be done for yours. Understand though that the Block will insert at that Basepoint location and adding the Basepoint at this time may result in some wierd behavior to your block.
There is not a solution that I am aware of at this time.
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
