Dynamic Blocks Forum
Moving Text with Constraints in a DB.
2 REPLIES 2
troy
518 Views, 2 Replies
Maybe I missed something. This is really basic if you use parameters and an action, create a linear parameter and associate a move or stretch with it. But you can not do this with Constraints. What is the best way to move text in a constraint setting? I have attached a .DWG with what i am attempting to do. The Attribute on the bottom right needs to move with the right line and at the same rate.
Thanks for any help in advance.
2 REPLIES 2
kruuger
in reply to: troy
just add another horizontal constrain from edge of panel to text (node point).
make sure that your snap to NODE is on.
troy
in reply to: troy
Thanks for the help.
”Boost
”Tips
”Services
