Dynamic Blocks
Dynamic Blocks
Active Contributor
0 Kudos
Post 1 of 3
Moving Text with Constraints in a DB.
151 Views, 2 Replies
02-12-2010 08:42 AM
Maybe I missed something. This is really basic if you use parameters and an action, create a linear parameter and associate a move or stretch with it. But you can not do this with Constraints. What is the best way to move text in a constraint setting? I have attached a .DWG with what i am attempting to do. The Attribute on the bottom right needs to move with the right line and at the same rate.
Thanks for any help in advance.
Active Contributor
0 Kudos
Post 2 of 3
Re: Moving Text with Constraints in a DB.
02-20-2010 01:37 PM in reply to: troy
just add another horizontal constrain from edge of panel to text (node point).
make sure that your snap to NODE is on.
Active Contributor
0 Kudos
Post 3 of 3
02-22-2010 10:33 AM in reply to: troy
Thanks for the help.
