Dynamic Blocks Forum
lookup choices
22 REPLIES 22
Message 1 of 23
792 Views, 22 Replies
lookup choices
trying to create a spec sheet that will allow me to touch a drop down arrow and let me choose from a list. I have a lookup parameter and then I assigned lookup action to it. It will not let me choose a parameter (none listed) try to load block and grips don't appear. I can only type in lookup properties box. any idea?
22 REPLIES 22
Message 21 of 23
in reply to: Charles_Shade
okay i figured it out   i typed  (visibility_add)  it worked  thanks
Message 22 of 23
vsrisaichaitanya
THIS CAN BE POSSIBLE WITH ATTRIBUTES , BY CREATING THREE ATTRIBUTES LINK THEIR FIELD WITH LOOP UP TABLE....I  MODIFIED YOUR DRAWING,SEE ATTACHMENT , AFTER CHANGING LOOPUP VALUES GIVE REGEN COMMAND....FOR ATTRIBUTE CHANGING
Message 23 of 23
Libbya
in reply to: vsrisaichaitanya
You are on the right track, but the issue with doing it the way you posted is that the text after the attribute does not adjust to the string length of the field.  If you choose a longer length, the text of the field writes on top of the text that is not part of the field.  If you choose a shorter length, there is an overly large gap in the text.  Here is a solution that does not use visibility states and still formats correctly regardless of the lookup choice.  A regen is required after each lookup change.
”Boost
”Tips
”Services
