Dynamic Blocks Forum
Linear parameter linked max distance
2 REPLIES 2
368 Views, 2 Replies
Is there a way to link the maximum distance of a linear parameter to a stretch handle.
See attached block. I want to restrain the line from going outside the stretching box (moving to the left (min. dist.) is OK, not so to the right (max. dist.). I'm stuck to input a maximum distance of the line's linear parameter. Can a Diesel Expression or link be use there?
Thank you
Luc T.
2 REPLIES 2
tlindell
If you have non-LT version of AutoCAD, the attached is one way to constrain it. There is no built-in way do it otherwise.
Thank you... This is very helpful!
”Boost
”Tips
”Services
