Is there a way to link the maximum distance of a linear parameter to a stretch handle.
See attached block. I want to restrain the line from going outside the stretching box (moving to the left (min. dist.) is OK, not so to the right (max. dist.). I'm stuck to input a maximum distance of the line's linear parameter. Can a Diesel Expression or link be use there?
Thank you
Luc T.
