Dynamic Blocks
Dynamic Blocks
New Member
RobinGins
Message 1 of 3 (370 Views)
Limit a stretch or move, but with a variable value ?? possible ??
370 Views, 2 Replies
12-17-2011 03:12 AM
Hi all,
I would like to find a way to give a maximum and minimum length to a stretch (or move) but without absolute values.
simplified example of my block:
I have 2 squares, of which one big on, and a smaller one within the bigger one. I want to be able to stretch both squared indefinatly (no problem there), but the big square may never become smaller than the small one, and the small one may never become bigger than the big one...
In other words: the inside square should always stay inside the bigger one, no matter the size of the squares.
The problem with this block is that I have a hatch pattern between the squares, and as soon as i stretch the small square outside (or equal) to the big square... the hatch pattern 'crashes'.
Please Help!
Thanks!
Charles_Shade
Message 2 of 3 (360 Views)
Re: Limit a stretch or move, but with a variable value ?? possible ??
12-19-2011 06:07 AM in reply to: RobinGins
How would you propose the Variable to know that you needed to abandon the Stretch Action at some point that approached the maximum size of the adjacent square?
I'll ask because I do not know - Does Lisp have an if/then cability?
And are you in something other than LT that can use Lisp?
As far as the Hatch crashing - Is the Hatch included in any of the Actions in the DynBlk?
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
Distinguished Contributor
REID7800
Message 3 of 3 (348 Views)
12-26-2011 08:04 AM in reply to: Charles_Shade
You can controll this with a reactor (lisp) but reactors can be tricky. I'll make one and you can decide if it's right for you. I'm away from autocad so you'll have to test it for me. I'll get back to you later today
_____
Reid B.
_____
Acad 2015
Architecture 2010
