Is there a way to move an atribute using a Constraint Parameter, when you can not connect the parameter directly to the insertion point, or is this idea simply a dead end?
The reason to use a constraint parameter rather than ie. a strecth action, is that this would make it possible to control the position dependent on other properties in a Block Properties Table.
Ebbe T. Hansen
Solved by Libbya. Go to Solution.
I do not think you can do that. However, you may be able to accomplish what you are desiring using a stretch action and lookup table instead of block properties.
You are absolutely right - it works fine. It is new to me that there is this distinction between Properties Table and a Lookup Table, and I am shure this will be usefull knowledge later on.
Thanks for your input
/Ebbe
