Dynamic Blocks
Dynamic Blocks
Valued Contributor
WillieArolf
Message 1 of 3 (231 Views)
Is it possible to make this objects a Dynamic Block
231 Views, 2 Replies
12-16-2012 11:57 PM
Hi Guys,
I am not so familiar with Dynamic Blocks so bare with me. I do have an object with different size and different number of sub-parts (MQRF). Would it be possible to make a "LOOKUP" dynamic block of it. If yes, what are the procedure in making it.
I have attach the dwg file 2012 ver.
Appreciate any info.
Thanks & Regards,
Willie
Autodesk Product Design Suite Premium 2012
Windows 7, 64-bit
There are multiple ways of doing this dynamic, if you want it simple you could make it with visibility states. Example attached, otherwise you could do it with lookup which would require multiple parameters and actions in order to present the correct object.
Valued Mentor
AcadAdamLT
Message 2 of 3 (222 Views)
Re: Is it possible to make this objects a Dynamic Block
12-17-2012 01:54 AM in reply to: WillieArolf
Signature, sincerely... //Adam
AutoCad LT 2014
Give Kudos where credit is due, Mark "accepted as solution" if the post solved your question.
Valued Contributor
WillieArolf
Message 3 of 3 (206 Views)
12-17-2012 04:27 PM in reply to: AcadAdamLT
AcadAdamLT
Thank you for the feedback. I have done it using Visibility.:smileyhappy:
Thanks & Regards,
Willie
Windows 7, 64-bit
