Dynamic Blocks Forum
Is it possible to make this objects a Dynamic Block
2 REPLIES 2
WillieArolf
479 Views, 2 Replies
Hi Guys,
I am not so familiar with Dynamic Blocks so bare with me. I do have an object with different size and different number of sub-parts (MQRF). Would it be possible to make a "LOOKUP" dynamic block of it. If yes, what are the procedure in making it.
I have attach the dwg file 2012 ver.
Appreciate any info.
Thanks & Regards,
Willie
Autodesk Inventor Professional 2019
Windows 7, 64-bit
2 REPLIES 2
AcadAdamLT
in reply to: WillieArolf
There are multiple ways of doing this dynamic, if you want it simple you could make it with visibility states. Example attached, otherwise you could do it with lookup which would require multiple parameters and actions in order to present the correct object.
Signature, sincerely... //Adam
AutoCad LT 2016
Give Kudos where credit is due, Mark "accepted as solution" if the post solved your question.
WillieArolf
in reply to: AcadAdamLT
AcadAdamLT
Thank you for the feedback. I have done it using Visibility.Smiley Happy
Thanks & Regards,
Willie
Windows 7, 64-bit
”Boost
”Tips
”Services
