Dynamic Blocks Forum
Incremental parameter 'ticks' invisible
1 REPLY 1
Martyn_Hemming
310 Views, 1 Reply
I've got a DB drawing frame that's working really nicely, but with one irritation. I've got a linear parameter linked to a stretch action, the parameter is set to increment. In block editor the 'ticks' that show the increments show up fine because of the background colour, but in paper space where the block is to be inserted the 'ticks' are the same grey colour as the space outside of the currently defined page. The stretch action will always be stretching outside the defined page so the ticks are never visible!
Is there anyway to change either the default grey colour for the incremental ticks, or the default grey colour for the space outside of the currently defined page?
Cheers,
Martyn
1 REPLY 1
sschwartz
in reply to: Martyn_Hemming
You could uncheck the "Display Paper Background" setting under options/layout elements.
”Boost
”Tips
”Services
